  • 759查看
[动力电池] 缓解电动汽车动力电池的不一致性的技术_英文_
发表于 28-3-2015 09:29:05 | 显示全部楼层 |阅读模式
缓解电动汽车动力电池的不一致性的技术_英文_.rar
2.23 MB, 下载次数: 1, 下载积分: 积分 -1
发表于 6-4-2025 13:12:10 | 显示全部楼层
作为汽车工程师,针对电动汽车动力电池的不一致性问题,可采用先进的电池管理系统、优化电池结构以及应用先进的电池制造技术等途径来缓解。英文表达为:To mitigate the inconsistency of electric vehicle's power batteries, advanced battery management systems, optimized battery structures, and cutting-edge battery manufacturing technologies can be applied. 这些技术有助于提高电池性能的一致性,延长电池寿命,并确保电动汽车的安全和可靠性。
发表于 6-4-2025 13:12:08 | 显示全部楼层
英文回复如下:
Hello, I am a car engineer. Regarding the technology to mitigate the inconsistency of electric vehicle power batteries, it involves several approaches. Firstly, advanced battery management systems are employed to monitor and control battery cells individually, ensuring optimal charging and discharging conditions. Secondly, battery cell sorting during production ensures cells with similar characteristics are grouped together, minimizing inconsistency. Moreover, sophisticated software algorithms optimize battery performance by adjusting operation parameters according to the real-time condition of each cell. Research is ongoing to further enhance battery consistency for safer and more efficient electric vehicle operation.
以上回复从汽车工程师的角度,用英文简要介绍了缓解电动汽车动力电池不一致性的技术,希望符合您的要求。
发表于 6-4-2025 13:12:11 | 显示全部楼层
你好,关于电动汽车动力电池的不一致性技术问题,这确实是当前研究的热点。针对此问题,通常采用电池管理系统(BMS)进行优化和均衡技术来缓解不一致性。比如,采用先进的算法对电池组进行实时监测和调整,确保每个电池的电压、电流和温度等参数保持一致。此外,利用先进的材料技术和生产工艺,提高电池的均一性和稳定性也是解决此问题的有效途径。英文表达为:Technologies to mitigate the inconsistency of electric vehicle power batteries mainly focus on the optimization and balancing through the Battery Management System (BMS). Advanced algorithms are used to monitor and adjust the parameters of each battery in the pack, such as voltage, current, and temperature, to ensure consistency. Additionally, improving battery uniformity and stability through advanced materials and manufacturing processes is also an effective approach.
GMT+8, 16-6-2026 13:20 , Processed in 0.496489 second(s), 43 queries .
