  • 639查看
软件工程师ESS专家
    发表于 22-12-2015 15:01:22 | 显示全部楼层 |阅读模式
    JOB OBJECTIVES/岗位设立目的:
    (Describe the reason why the  position needs to be set up with 1-2 sentences/ 1-2句话描述设置该职位的目的)
    This position is responsible for the design and implementation of ESSM(Engine Start Stop Master) for SESAM ECU.
             这个岗位主要负责为SESAM ECU(车载电脑)设计和实现ESSM(发动机启动和停止装置)
    JOB SCOPE/岗位责任范围:
    (Describe the responsible area or authorization of the position holder/描述该职位的 职权或负责的业务范围)
    Responsible for the ESSM SW module design, developing, validation and integration
    负责ESSM SW模块设计、开发、验证和集成
    Communication of ESS(Engine Start Stop) functionality with project team and global module responsible
    负责ESS(发动机启动停止)功能与项目团队的通信以及负责全球模块
    MAIN RESPONSIBILITIES/主要职责:
    (Key job focuses and responsibilities to reflect critical successful factors(CSF)/成功达成职位目标的关键职责)
    Support system engineer communicating with customer to coordinate and clarify ESS requirement.
    支持系统工程师与客户沟通协调,明确ESS(电子开关转换系统)的要求。
    Communicate in project team to understand system and software architecture and adapt according to ESSM needs.
    帮助项目团队内交流,理解系统以及根据ESSM适应软件架构。
    Understand ESSM running environment, define and design ESSM SW interface together with related module responsible.
    理解ESSM运行环境,定义和设计ESSM SW界面,同时负责相关模块。
    Create ESSM SW requirement based on customer or system requirement
    根据客户或系统要求创建ESSM SW需求
    Develop ESSM software module with Matlab(Simulink/Statemate) and TargetLink according to Marquardt programming rules and compliance with Autosar.
    根据马夸特编程规则和适用于Autosar的规则使用Matlab(Simulink/Statemate)和TargetLink开发ESSM软件模块与Matlab仿真软件
    Create ESSM SW validation specification, perform module test(TPT) and integration test.
    创建ESSM SW验证规范,执行模块测试(TPT)和集成测试。
    In field supporting for ESS functionality applying in vehicle.
    在汽车领域支持ESS功能应用。
    Organize training in SW team to ensure ESSM knowledge transfer.
    组织培训SW团队以确保ESSM知识传递。
    MINIMUM POSITION REQUIREMENTS (MUST HAVE)/基本岗位任职条件:
    (Minimum requirements on education, training, industry experience , skills/competencies, etc. to fulfill the  position /列举岗位所需最低教育、培训、行业经验、技能、技巧等)
    At least Bachelor degree with major in Computer Science, Information technology, automotive, or related.
    至少学士学位,主修计算机科学、信息技术、汽车、或相关专业
    At least 5 years work experience in automotive embedded software design
    至少5年的汽车嵌入式软件设计的工作经验
    At least 2 years work experience with Matlab(Simulink/Statemate) and TargetLink code generating.
    至少在Matlab仿真软件/ Statemate TargetLink代码生成方面有2年工作经验。
    Good understanding and experience of ESS functionality.
    在ESS功能方面具有良好的理解和经验。
    Good experience with AUTOSAR and with the necessary configuration tools
    在AUTOSAR和必要的配置工具方面具有良好的经验
    Good understanding of automotive software and product development process
    在汽车软件和产品开发过程方面具有良好的理解
    Good knowledge of Doors, Dimensions.
    了解门的规格
    Good knowledge of Requirement engineering and change management.
    了解需求工程和变更管理
    Strong ability to use various software development tools and programming languages such as CANoe, TRACE32, C.
    具有较强的使用各种软件开发工具和编程语言的能力,如CANoe,TRACE32, C
     楼主| 发表于 22-12-2015 15:03:23 | 显示全部楼层
    英特力斯工程管理(宁波)有限公司 猎头顾问JOJO 电话13486696093  QQ3161773374
    GMT+8, 27-3-2026 19:01 , Processed in 0.382234 second(s), 32 queries .
