  • 4815查看
[求助] cruise运行仿真有些问题
    慵懒
    25-4-2019 14:33
    发表于 24-4-2019 15:54:46 | 显示全部楼层 |阅读模式
    #1
      library not loaded...
      ERROR H_102: MH_LoadOnlineMonitorLib_DP
    慵懒
    25-4-2019 14:33
     楼主| 发表于 24-4-2019 15:55:53 | 显示全部楼层
    #1
      [MatLab DLL.17]: xiexing
      The vector length for the data transfer between CRUISE and Matlab DLL does not match the number of connections actually made.
      WARNING M_283: CheckNumberOfConnections_90
    #2
      Error in opening Online Monitor
      WARNING H_103: MH_OpenOnlineMonitor_DP
    #3
      Voltage break down as no equlibrium could be achieved.
      It appears that there are only sources or only sinks in the net.
      Information:
       - Could be caused by an overloading of a battery.
       - Maybe Terminal is applying current to the network without consumer.
      t 0: u_high 1180 i_sum 0.508477
        WARNING S_105: EM_CalculateNetEquilibrium
    #4
      Information:
    #5
      Current equlibirium could not be achieved as voltage is at the lower limit. Current equlibrium  -18435.2, t 0.
    warings也有5个
    运行的时候下面什么东西也没出现 一片黑色的  就看着进度条运行完 然后什么也没有
    GMT+8, 9-5-2026 09:57 , Processed in 0.388499 second(s), 32 queries .
