  • 2827查看
Audi 奥迪 OBD2 TDC
发表于 17-7-2011 18:49:11 | 显示全部楼层 |阅读模式
p1102 oxygen sensor heating circuit bank 1-sensor 1 short to b+
p1105 oxygen sensor heating circuit bank 1-sensor 2 short to b+
p1107 oxygen sensor heating circuit bank 2-sensor 1 short to b+
p1110 oxygen sensor heating circuit bank 2-sensor 2 short to b+
p1127 long term fuel trim multiplicative bank 1 system too
p1128 long term fuel trim multiplicative bank 1 system too
p1129 long term fuel trim multiplicative bank2 system too rich
p1130 long term fuel trim multiplicative bank2 system too lean
p1136 long term fuel trim additive bank 1 system too lean
p1137 long term fuel trim additive bank 1 system too rich
p1138 long term fuel trim additive fuel bank 1 system too lean
p1139 long term fuel trim additive fuel bank 1 system too rich
p1141 load calculation cross check range/performance
p1176 oxygen correction behind catalyst b1 limit attained
p1177 oxygen correction behind catalyst b2 limit attained
p1196 oxygen sensor heater circuit bank 1-sensor 1 electrical malfunction
p1197 oxygen sensor heater circuit bank 2-sensor 1 electric malfunction
p1198 oxygen sensor heater circuit bank 1-sensor 2 electrical malfunction
p1199 oxygen sensor heater circuit bank 2-sensor 2 electrical malfunction
p1201 cylinder 1 fuel injection circuit electrical malfunction
p1202 cylinder 2 fuel injection circuit electrical malfunction
p1203 cylinder 3 fuel injection circuit electrical malfunction
p1204 cylinder 4 fuel injection circuit electrical malfunction
p1205 cylinder 5 fuel injection circuit electrical malfunction
p1206 cylinder 6 fuel injection circuit electrical malfunction
p1207 cylinder 7 fuel injection circuit electrical malfunction
p1208 cylinder 8 fuel injection circuit electrical malfunction
p1213 cylinder 1 fuel injection circuit short to b+
p1214 cylinder 2 fuel injection circuit short to b+
p1215 cylinder 3 fuel injection circuit short to b+
p1216 cylinder 4 fuel injection circuit short to b+
p1217 cylinder 5 fuel injection circuit short to b+
p1218 cylinder 6 fuel injection circuit short to b+
p1219 cylinder 7 fuel injection circuit short to b+
p1220 cylinder 8 fuel injection circuit short to b+
p1225 cylinder 1 fuel injection circuit short to ground
p1226 cylinder 2 fuel injection circuit short to ground
p1227 cylinder 3 fuel injection circuit short to ground
p1228 cylinder 4 fuel injection circuit short to ground
p1229 cylinder 5 fuel injection circuit short to ground
p1230 cylinder 6 fuel injection circuit short to ground
p1237 cylinder 1 fuel injection circuit open circuit
p1238 cylinder 2 fuel injection circuit open circuit
p1239 cylinder 3 fuel injection circuit open circuit
p1240 cylinder 4 fuel injection circuit open circuit
p1241 cylinder 5 fuel injection circuit open circuit
p1242 cylinder 6 fuel injection circuit open circuit
p1250 fuel level too low
p1280 fuel injection air control valve circuit flow too low
p1283 fuel injection air control valve circuit electrical malfunction
p1325 cylinder 1 knock control limit attained
p1326 cylinder 2 knock control limit attained
p1327 cylinder 3 knock control limit attained
p1328 cylinder 4 knock control limit attained
p1329 cylinder 5 knock control limit attained
p1330 cylinder 6 knock control limit attained
p1331 cylinder 7 knock control limit attained
p1332 cylinder 8 knock control limit attained
p1337 camshaft position sensor bank 1 short to ground
p1338 camshaft position sensor bank 1 open circuit/short
p1340 boost pressure control valve short to b+
p1386 internal control module knock control circuit error
p1391 camshaft position sensor bank 2 short to ground
p1392 camshaft position sensor bank 2 open circuit/short
p1410 tank ventilation valve circuit short to b+
p1420 secondary air injection module short to b+
p1421 secondary air injection module short to ground
p1421 secondary air injection valve circuit short to ground
p1422 secondary air injection system control valve circuit short to b+
p1422 secondary air injection valve circuit short to b+
p1425 tank vent valve short to ground
p1426 tank vent valve open
p1432 secondary air injection valve open
p1433 secondary air injection system pump relay circuit open
p1434 secondary air injection system pump relay circuit short to b+
p1435 secondary air injection system pump relay circuit short to ground
p1436 secondary air injection system pump relay circuit electrical malfunction
p1450 secondary air injection system circuit short to b+
p1451 secondary air injection system circuit short to ground
p1452 secondary air injection system open circuit
p1471 evap emission control ldp circuit short to b+
p1472 evap emission control ldp circuit short to ground
p1473 evap emission control ldp circuit open circuit
p1475 evap emission control ldp circuit malfunction/signal circuit open
p1476 evap emission control ldp circuit malfunction/insufficient vacuum
p1477 evap emission control ldp circuit malfunction
p1500 fuel pump relay circuit electrical malfunction
p1501 fuel pump relay circuit short to ground
p1502 fuel pump relay circuit short to b+
p1505 closed throttle position switch does not close/open circuit
p1506 closed throttle position switch does not open/short to ground
p1507 idle system learned value lower limit attained
p1508 idle system learned value upper limit attained
p1512 intake manifold changeover valve circuit - short to b+
p1515 intake manifold changeover valve circuit - short to ground
p1516 intake manifold changeover valve circuit - open
p1519 intake camshaft control - bank 1 malfunction
p1522 intake camshaft control - bank 2 malfunction
p1543 throttle actuation potentiometer signal too low
p1544 throttle actuation potentiometer signal too high
p1545 throttle position control malfunction
p1547 boost pressure control valve - short to ground
p1548 boost pressure control valve open
p1555 charge pressure upper limit exceeded
p1556 charge pressure negative deviation
p1557 charge pressure positive deviation
p1558 throttle actuator electrical malfunction
p1559 idle speed control throttle position adaptation malfunction
p1560 maximum engine speed exceeded
p1564 idle speed control - throttle position low voltage during adaptation
p1580 throttle actuator (b1) malfunction
p1582 idle adaptation at limit
p1602 power supply (b+) terminal 30 low voltage
p1606 rough road spec engine torque abs-ecu electrical malfunction
p1611 mil call-up circuit/transmission control module short to ground
p1612 electronic control module incorrect coding
p1613 mil call-up circuit open/short to b+
p1624 mil request signal active
p1625 can-bus implausible message from transmission control
p1626 can-bus missing message from transmission control
p1640 internal control module (eeprom) error
p1681 control unit programming not finished
p1690 malfunction indicator light malfunction
p1693 malfunction indicator light short to b+
p1778 solenoid ev7 electrical malfunction
p1780 engine intervention readable
    慵懒
    25-11-2015 16:01
  • 签到天数: 12 天
    发表于 5-11-2015 10:47:15 | 显示全部楼层
    顶起,虽然我用不到啊,求下载分啊
    发表于 18-11-2015 22:16:20 | 显示全部楼层
    670是免费升级的吗
    GMT+8, 14-6-2026 15:24 , Processed in 0.529897 second(s), 39 queries .
