  • 1609查看
[讨论] EBD是怎么工作的?
    发表于 13-8-2012 22:43:21 | 显示全部楼层 |阅读模式
    EBD是怎么工作的呢,他依据什么判断(技算)地面不同摩擦力的?和ABS有什么不同?
    发表于 14-8-2012 15:31:25 | 显示全部楼层
    通过滑移率对比判断,ABS是在滑移率超出临界值,轮胎要打滑的时候才介入,EBD在此之前就已经介入,分配前后轴的制动力
    发表于 8-9-2012 21:59:44 | 显示全部楼层
    If during normal braking the rear axle of the vehicle is locking earlier than the front axle, then stability of the vehicle is largely compromised.
    The EBD ensures that the rear wheels are monitored to the sensitivity of wheel slip. If slip is detected, then pressure for the rear wheels is held and a further pressure build-up on the rear brakes is thus avoided.
    EBD may also perform a pressure decrease on the rear axle, if the slip begins to increase.
    GMT+8, 22-4-2026 07:19 , Processed in 0.486790 second(s), 40 queries .
